CSA Network Shim
I deployed CSA to a laptop and during install I did not install the network shim because since I have multiple VPN clients it might present a problem. I see in the Event Monitor this(The Network Shim is not installed/enabled on this agent, but the rules that apply to this agent require the network shim to be enabled. Functionality will be degraded until the network shim is installed.) What will be degraded and how do I install the shim on an agent already running. I see it is rule 80 Common Security Module and is enabled. Thanks
Re: CSA Network Shim
The following Security Applications use the Network Intercetor:
Distributed firewall
Host intrusion detection
Network worm prevention
Host intrusion detection and Network worm prevention also use the Execution Space interceptor so they will stop some things but not others.
To get the network shim on the host re-install the agent.
Hope this helps.
BC
Thanks, that's what I figured.
167
