CSA Report Viewing ActiveX problem IE7
When I am trying to run the reports in CSA they work fine, in HTML format. However when I am trying to view them in activeX, it comes back on IE7, telling me it cannot access the resource and that I need to install IE4 and DCOM for windows 95. I am sure that I am simply over looking something. Suggestions?
1 ACCEPTED SOLUTION
Blue
Re: CSA Report Viewing ActiveX problem IE7
Blue
What version of CSA? Might just need to clear cookies...
CWCS Foundation 2.2 3-16-2006 17:35:30 ENABLED
Management Center for Cisco Security Agents V5.0 5.0 5-24-2006 09:55:18 ENABLED
Monitoring Center for Performance 2.0.2 3-16-2006 17:35:30 ENABLED
IPS MC 2.2 3-22-2006 16:50:51 ENABLED
Security Monitor 2.2 3-22-2006 16:50:51 ENABLED
Management Center for Firewalls 1.3 3-16-2006 17:35:31 ENABLED
Router-MC 1.3.1 3-16-2006 17:35:31 ENABLED
Blue
Did you try clearing the cookies? It worked when I had problems displaying items before.
I think the IE7 problem is different though and I noticed it after the last Cumulative IE update.
Yes. IE7 / Tools / internet options / general tab / browsing history / delete / Cookies and Temp Interent files.
The exact error message I get, when I click view report. A new window opens, I get a pop up and it says...
"The Seagate ActiveX viewer is unable to create it's resource objects. To rectify this problem, please install Internet Explorer 4.0 or install DCOM for Windows 95 and the latest Microsoft Scripting Engine. These files are available at Microsoft's web site."
I click OK, and it pops right back up again, forcing me to end task on the process. This is not just my PC but all of the IE7 PC's that I am using. I would use Firefox however, I am unable to "print" the report in the HTML formats.
Thanks again for your time and efforts on this issue.
Blue
You sir.. are fantastic!!! RESOLVED - Solution :
To Resolve:
1. Open up Internet Explorer 7
2. From the Tools menu, select Internet Options
3. From the new popup window, select the Security tab
4. Ensure that you highlight Internet
5. Click on the button named Custom level
*The Security Settings menu will now come into view*
6. Scroll down the settings until you reach "ActiveX controls and plug-ins"
7. Ensure the settings are as below -
Allow previously unused ActiveX controls to run without prompt
Enable
Allow Scriptlets
Disable
Automatic prompting for ActiveX controls
Enable
Binary and script behaviours
Enable
Display video and animation on a web page that does not use external media player
Disable
Download signed ActiveX controls
Prompt
Download unsigned ActiveX controls
Disable
Initialize and script ActiveX controls not marked as safe for scripting
Disable
Run ActiveX controls and plug-ins
Enable
Script ActiveX controls marked as safe from scripting*
Enable
Please ensure that you click OK, once finished ? to save
Blue
Glad to help.. Please do the checkbox thingy on the solution so that others may see it as a solution.
Tom
362
