Community Member
CSA v5.0 - Best practices > Analysis Deployment Investigation
Question 1: CSA finds the following CSA related files in Unknown Applications: compile.exe; leventmgr.exe; okclient.exe; and query.exe. What is the best practice to do with these executables with regards to Product Association and Application Classes as CSA does not sort these out for itself.
Questions 2: In Analysis > Application Deployment Investigation > Product Association, what is the best practice to map Windows XP Hotfixes and XP Security Updates to which Application Class, is there a class already created or would I create a new one?
1 REPLY
Silver
Re: CSA v5.0 - Best practices > Analysis Deployment Investigatio
You have mentioned that "compile.exe; leventmgr.exe; okclient.exe; and query.exe files are found in unknown applications". Now, can you let me know those application names which you are referring to as unknown?. With that, we can find out what those applications are and how they are related to the above mentioned executable files.
279
