Community Member
CSA v5.1 Backup and Restore Procedure with Remote SQL Database
My question relates to a CSA v5.1 with remote SQL DB installation. Does someone know of, or could provide me with a procedure explaining the steps required to successfully backup and restore a CSA MC server with remote DB?
Cisco documentation only describes how to backup and restore a local database using the ?restore utility? in the CSAMC51\bin directory. But I don?t think that this utility can be used when you have a remote DB. So what are the manual steps required to perform this task?
Any ideas?
1 REPLY
Community Member
Re: CSA v5.1 Backup and Restore Procedure with Remote SQL Databa
The SQLServer - if remote - needs to be backed-up and restored based on
SQLServer's own backup and restore utility.
While i do not have one for 5.1 I have attached steps for 4.5 and they should be similar with some database names that are different. See if this helps.
Glenn
283
