CSACSE-1112-K9 - v4.2 - config/device recovery
Peter Zsiros
hope you can guide me to the right direction to resolve this issue.
I have a problem exporting the config from a 1112 appliance.
It does not boot up properly. GUI logon and authentication is not possible.
I can console and SSH to it but the only thing i get is the commands below and nothing else.
login as: admin
admin@10.10.1.126's password:
Last login: Wed May 30 11:11:42 2012 from jsmith
Could not chdir to home directory /home/admin: No such file or directory
acs> help
API called before initialised at V:\ismg_israel_acs\Acs\EndPoint\Core\endpoint.cpp:395
Command                  Description
?                    List commands
exit                 Log off
help                 List commands
csutil -dumpadmin    Dump Admin Audit Information
csutil -dumpgroups   Dump Group Audit Information
csutil -dumpusers    Dump User Audit Information
csdbsync -syncnow    RDBMS synchronization
acs>
Any ideas how could i get the config and/or get it work again?
Thx!
Peter
The database seems to be corrupt. I would suggest you reimaging the box with 4.2 recovery CD. However, it seems you don't have any current or older database that we can restore back to ACS.
NOTE: reimage will delete all the configuration from the ACS SE.
What changes pushed you down in this situation? Did you try to upgrade the code or patch on it?
Jatin
Do rate helpful posts-
~Jatin
5 Replies 5
Jatin Katyal
SSH connection would only should you limited commands and that is an expected behaviour.
You need to establish a console connection if you would like to take back of your current configuration.
Establishing serial/console connection
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2/installation/guide/solution_engine/instalap.html#wp1065399
Backing upi ACS data from serail console connection
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2/installation/guide/solution_engine/admap.html#wp1057928
What error are we getting during the bootup process?
Did you check the status of the services? This can be checked by running "show" command from console session.
Csadmin should be running in order to access it through web gui.
Do let me know if you need further help.
Jatin
~Jatin
A colleague already tried console cable access as well.
When he tried to do a backup it kept failing with "Can not initialize SchemeLayerBackup File does not exist!".
He also checked services: not running
Rebooting the device did not help.
Jatin
~Jatin
I thought it will be something serious.
Re-imaging is not that painful as this unit is part of a 3 device cluster. I assume it will sync the DB as soon as it is back in the cluster. I just wanted to have a backup which i may import after re-imaging the device.
As usual in these cases: "nothing happened", "nothing has been changed". Either they don't know or don't want to tell me.
Thank you for your help!
If it's in cluster then that would be great. reimage it and put the bare-minimum configuration for replication to work.
here is a configuration example of setting up replication between ACS 4.2
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080742f60.shtml
The following items cannot be replicated so that you need to add.
•IP pool definitions (for more information, see About IP Pools Server).
•ACS certificate and private key files.
•Dynamically-mapped users.
•Settings on the ACS Service Management page in the System Configuration section.
•RDBMS Synchronization settings.
Jatin
~Jatin
