CSAdmin do not stop
Hi, I have a problem...
I'm trying to upgrade my ACS from 4.1.3.12 to 4.1.3.12.2, but the CSAdmin service do not stop.
Is there any bug in this version (4.1.3.12)?
Plataform: ACS Appliance 1111
Help me!
Cristiano
Re: CSAdmin do not stop
How you are trying to upgrade it ? There is no need to stop csadmin in acs appliance.
~JG
Hello JG... Thanks for your quick reply!
I'm trying to upgrade through serial connection, using the commands:
- download
The download is performing. Ok!
After that I insert the command:
- upgrade
So the proccess try to stop all services before begin the upgrade, but the CSAdmin service don't stop.
The following error is displayed:
!!! Failed to stop CSAdmin !!!
Any idea?
Cristiano
Make sure CSA is disabled before you try to upgrade. Also did you try to upgrade via GUI ?
Hi JG...
Unhappyly I did not get success in my attempts.
The solution was to remove the 4.1.3.12 and to install the 4.1.2.12 version...
Now my ACS's are ok...
Thanks for your attention!
Cristiano
234
