CSC-SSM Default Management Port...
Does anyone know how to change this port from it's default of 8443?
Please let me know, it's urgent!
Eddie
Re: CSC-SSM Default Management Port...
You can change this trough the initial setup of setup screen...
See this document:
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a0080693b38.html
There it's explained
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
Ummm...where?
Have you actually read the doc?
Silver
Even i went through the doc again and again. And the only one reference i seem to notice is this :
1. Network Settings
2. Date/Time Settings
3. Product Information
4. Service Status
5. Change Password for Command Line Interface
6. Restore Factory Default Settings
7. Troubleshooting Tools
8. Reset Management Port Access Control List
9. Ping
10. Exit ...
The 8th point.
Choose option 8 to reset the management port access control list. The following appears:
Resetting management port access control list: OK
Press Enter to continue ...
If the ASDM is unable to communication with the SSM, try resetting port access via this option
But even that doesn't explain if we could change the port. I have a CSC to configure next week, wish i had this box looks fun to play with.
Cheers
Hoogen
137
