CSCsa04030 bug fix for VMS MC 2 & IDS 4x
We are looking for the description / conversation of bug fix CSCsa04030, which Cisco said will be released in the summer to fix the signature deployment/update issue between a NAT VMS MC and IDS 4x.
Appreciate if you can pin point us to where can we find the description of bug fix CSCsa04030.
Is your VMS MC behind the firewall?
Do you have problem updating signature on IDS 4x via a natted VMS MC?
How do you get around it besides SSH to the sensor and manually run the upgrade command?
TIA.
Simone.
1 REPLY
Bronze
Re: CSCsa04030 bug fix for VMS MC 2 & IDS 4x
Use the "Software Bug Toolkit" which can be found here:
http://www.cisco.com/kobayashi/support/tac/tools_trouble.shtml
When to "Bug Tool" launches, put the BugID (in this case, CSCsa04030) into the first input box and hit "Search"
Just checked it out myself and found that there is something there for BugID CSCsa04030...
Alex
80
