csids monitoring interface
If you connect the monitoring interface which is 10/100 ethernet to a hub (which is 10Mbps no autonegotiation), would it work and start sniffing. IF not, how do you set the monitoring interface to 10Mbps. Also, regarding the reporting subsystem, I cofigured the Reports for Most visited FTP and WWW sites and user activity but I'm getting nothing although FTP services are configured to be logged in 'Configure Notification'. Also 'View Notification' is always empty. The only thing I'm getting populated is the 'Sensor events database' and 'Events summary' report (filled with info from the pix about denied outbound connections. Any clue of what could be missing? Note that the perimeter router is not configured to send syslog messages to the CSPM. Thanks.
Hussam
System Engineer
1 REPLY
Bronze
Re: csids monitoring interface
Auto negotiation should default to 10Mbps half-duplex when negotiation fails on physical link so it should work just fine. It sounds like you need a tac engineer to help you set this up and get your reporting working properly.
116
