CSM 3.3.1 : IP range or IP Pool in ACL
martin.payette
is there anyway to use an IP Range in a ACL?
I know there is Object-group...
I would like to use IP range like the VPN IP Pool.
Is it possible?
cheers
Panos Kampanakis
Unfortunately no.
The ACLs cannot support ip ranges, you can only use subnets with netmasks to group ip addresses.
I hope it is clear.
Panos Kampanakis
Unfortunately no.
I hope it is clear.
Thank you for your fast answer.
You confirm what I tought.... it would be a very nice add-on
