CSM 3.3.1 : IP range or IP Pool in ACL
is there anyway to use an IP Range in a ACL?
I know there is Object-group...
I would like to use IP range like the VPN IP Pool.
Is it possible?
cheers
1 ACCEPTED SOLUTION
Re: CSM 3.3.1 : IP range or IP Pool in ACL
Unfortunately no.
The ACLs cannot support ip ranges, you can only use subnets with netmasks to group ip addresses.
I hope it is clear.
Unfortunately no.
I hope it is clear.
Thank you for your fast answer.
You confirm what I tought.... it would be a very nice add-on
461
