CSM question?
Is the Cisco Security Manager a stand alone product or does it need Cisco Works?
Re: CSM question?
Cisco Security Manager can be a standalone product but bas has the Cisco Works Common Services Framework.
All services as SSL,http,ftp,tftp,smtp,snmp will always be based on Cisco Works.
Anyway when you install Security Manger it will automaticly install the Cisco Works Common Services.
Reference:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/secman/csm/301ig/requirem.htm
CiscoWorks Common Services 3.0.3 is required for Security Manager to work. You install Common Services, and apply a special patch to it, automatically when you install Security Manager server software. Security Manager cannot coexist on a server with any patched or unpatched version of Common Services earlier than the patched version from the Security Manager installation DVD.
sincerely
Patrick
Re: CSM question?
Thank you Patrick for the info and the link.
120
