CSPM 2.3.Ii crashing with stack overflow
Hi All,
The system I had running has worked fine but then the Alerts reached the limit set in preferences.
I deleted all rows and cleared out the alerts.
The CSPM keeps crashing now everytime I go into the view alerts option with the following message:
An Application error has occurred and
an application error log is being generated
fms.exe
Exception: stack overflow (0x0000fd), Address: 0x10266e2f)
A reboot does not fix the problem. I tried a reset as a last resort and that did not work either.
I assume I will have to deinstall and reinstall CSPM to get around it.
Any ideas or is this a known bug
thanks
inti
Re: CSPM 2.3.Ii crashing with stack overflow
How much memory do you have on your system?
-Mun
IDS PM
Please run the "cvtnrlog -d" command from
the command line and let us know what you see.
-Mun
The system is
Compaq DL360 866Mhz
256 MB Ram
18.2 GB Hard disk
NT 4.0 SP6a
I had to deinstall and reinstall the software.
The problem went away.
I am going to upgrade to CSPM 2.32i and wait and see
Inti.
121
