bz
CSPM and HIDS Console
Is it possible to install both CSPM and HIDS Console on the same server? Will it cause any configuration problems? Does anyone know when CSPM will support w2k? Thanks!
Re: CSPM and HIDS Console
CSPM 3.1 will be supported on W2k, scheduled in a couple of months.
R/Yusuf
CSPM and the HIDS console can co-exist on the same system. However, if CSPM is installed 1st you must stop the CSPM server service (CHC) before installing the HIDS console. If the HIDS Agent is also installed on the CSPM host, you might encounter problems if the Agent is in protection mode.
98
