CSPM notification script
Can I get a sample notification script for CSPM that sends email?
Unix Dir provided a sample script 'eventd' which included EventMessage. I want the plain english NSDB Signature Name in the email notification. e.g. for NSDB ID: 1102, I also want to see 'Impossible IP Packet'.
from http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids7/unix_cfg/advanced.htm#xtocid2528014
• $EventMessage—The generated alarm details, if any.
Re: CSPM notification script
Here is a perl script and a batch file that will read the signatures file and put signature names in the subject of the email. To use, set the notification script to the batch file that launches it. You must edit the emailEvent.pl script to setup the email server and location of the CSPM installation of Postoffice. You must edit the emailEvent.bat file to point to the installed Perl interpreter and emailEvent.pl script. The version of perl must support email. You can get the latest free version for Win32 from http://aspn.activestate.com/ASPN/Downloads/ActivePerl/.
=== emailEvent.bat ===
perl d:\n\emailEvent.pl %*
=== emailEvent.pl ===
# This script receives an event notification then looks up the
# signature name in a "signatures" file. Next the script
# generates an email appending the signature name to the
# default subject. The contents of the email is the parsed
# arguments of the event notification with the addition of
# the signature name.
use Net::SMTP;
### YOU NEED TO SET THESE or override them in emailEvent.config
$SMTP_Server = 'mailhost.yourdomain.com';
$email_from = 'nobody@yourdomain.com';
$email_to = 'nobody@yourdomain.com';
$email_subject = 'IDS';
$email_reply_to = 'nobody@yourdomain.com';
$signatures_file = 'D:\program files\cisco systems\cisco secure policy manager\Postoffice\etc\signatures';
# note, the format for overriding these defaults in the
# emailEvent.config file is:
# SMTP-Server=servername
# email-from=emailAddress
# email-to=emailAddress
# email-subject=subject
# email-reply-to=emailAddress
# Start here
&setup_defaults; # setup command defaults
&read_cmdline_args; # read in any cmd line args
&read_config_file; # read in the configuration file
&check_sanity; # is everything set to go.
&process; # process the bookmarks
exit 0; # terminate execution
##############################################################3
# help message
sub help
print <
emailEvent.pl - emails a CSPM event
This program takes an event notification and generates an e-mail
message.
usage:
emailEvent.pl MsgType RecordID GlobalTime LocalTime DateStr TimeStr
ApplID HostID OrgID SrcDirection DstDirection AlarmLevel
SigID SubSigID ProtocolType SrcIpAddr DstIpAddr SrcIpPort
DstIpPort RouterIpAddr AlarmDetails MsgCount
where:
MsgType Identifies an integer value indicating the event
type: 4 = Alarm. Note This value is always 4.
RecordID Identifies record ID for the event.
GlobalTime Identifies the GMT timestamp for when the event
was generated, expressed in seconds since
midnight, January 1, 1970 (time_t).
LocalTime Identifies (sensor-local) timestamp for when the
event was generated, expressed in seconds since
DateStr Identifies (sensor-local) date stamp for when
the event was generated, in YYYY/MM/DD format.
TimeStr Identifies (sensor-local) time stamp for when
the event was generated, in HH:MM:SS format.
ApplID Identifies (postoffice) application ID on the
sensor that generated the event.
HostID Identifies (postoffice) host ID of the sensor
OrgID Identifies (postoffice) organization ID on the
SrcDirection Identifies the location of the source (attacking)
entity with respect to the protected network.
Values are "IN" for inside the protected network,
or "OUT" for outside the protected network.
DstDirection Identifies location of the destination (attacked)
AlarmLevel Identifies the severity level of the alarm.
SigID Identifies the signature ID that triggered the
alarm.
SubSigID Identifies the sub-signature ID that triggered
the alarm, if applicable.
ProtocolType Identifies the protocol of the alarm - always
"TCP/IP".
SrcIpAddr Identifies the IP address of the source
(attacking) node.
DstIpAddr Identifies the IP address of the destination
(attacked) node.
SrcIpPort Identifies the IP port number of the source
(attacking) node.
DstIpPort Identifies the IP port number of the destination
(attacked) node.
RouterIpAddr Identifies the IP address of the router that sent
the syslog message to the sensor (10000 series
alarms only); otherwise 0.0.0.0
AlarmDetails Identifies the details and/or context data for
the alarm.
MsgCount Identifies the number of events that occurred in
the current interval that caused this notification
to be generated.
-help this message
END_HELP
# setup
sub setup_defaults
$config{'config-file'} = './emailEvent.config';
$config{'debug-level'} = 0;
$config{'SMTP-Server'} = $SMTP_Server;
$config{'email-from'} = $email_from;
$config{'email-to'} = $email_to;
$config{'email-subject'} = $email_subject;
$config{'email-reply-to'} = $email_reply_to;
$config{'signatures-file'} = $signatures_file;
# Read the command line args and update the %config hash
sub read_cmdline_args {
if($#ARGV < 21) {
help();
exit 0;
$cmdline{'MsgType'} = $ARGV[0];
$cmdline{'RecordID'} = $ARGV[1];
$cmdline{'GlobalTime'} = $ARGV[2];
$cmdline{'LocalTime'} = $ARGV[3];
$cmdline{'DateStr'} = $ARGV[4];
$cmdline{'TimeStr'} = $ARGV[5];
$cmdline{'ApplID'} = $ARGV[6];
$cmdline{'HostID'} = $ARGV[7];
$cmdline{'OrgID'} = $ARGV[8];
$cmdline{'SrcDirection'} = $ARGV[9];
$cmdline{'DstDirection'} = $ARGV[10];
$cmdline{'AlarmLevel'} = $ARGV[11];
$cmdline{'SigID'} = $ARGV[12];
$cmdline{'SubSigID'} = $ARGV[13];
$cmdline{'ProtocolType'} = $ARGV[14];
$cmdline{'SrcIpAddr'} = $ARGV[15];
$cmdline{'DstIpAddr'} = $ARGV[16];
$cmdline{'SrcIpPort'} = $ARGV[17];
$cmdline{'DstIpPort'} = $ARGV[18];
$cmdline{'RouterIpAddr'} = $ARGV[19];
$cmdline{'AlarmDetails'} = $ARGV[20];
$cmdline{'MsgCount'} = $ARGV[21];
# The config file name is the *ONLY config item
# we special case. That is if the config_file is
# set on the cmd line then we overrided the default
# value right now!
if( defined $cmdline{'config-file'}) {
$config{'config-file'}=$cmdline{'config-file'};
# Read the configuration file and update the %config hash
sub read_config_file {
$CONFIG_FILE=$config{'config-file'};
open CONFIG_FILE;
while( ) {
chomp;
($first, $second) = split( /=/ );
$config{$first}=$second;
# Check the sanity of the %config hash
sub check_sanity {
# First thing: Integrate the cmd line args with config args
foreach (keys %cmdline) {
$config{$_} = $cmdline{$_};
# Now lets print the whole shebang!
if( $config{'debug-level'} > 1) {
foreach (sort keys %config) {
print "$_ ==> $config{$_}\n";
# process
sub process
local @msgLines;
debug("debug is on");
# setup the %signatures hash
parseSignatures();
# get the signature name
$sigName = $signatures{$config{'SigID'}};
# append signature name to email subject
if($sigName ne "") {
$config{'email-subject'} = "$config{'email-subject'} ($sigName)";
# build text message to email in a string array
push(@msgLines, "MsgType = $config{'MsgType'}");
push(@msgLines, "RecordID = $config{'RecordID'}");
push(@msgLines, "GlobalTime = $config{'GlobalTime'}");
push(@msgLines, "LocalTime = $config{'LocalTime'}");
push(@msgLines, "DateStr = $config{'DateStr'}");
push(@msgLines, "TimeStr = $config{'TimeStr'}");
push(@msgLines, "ApplID = $config{'ApplID'}");
push(@msgLines, "HostID = $config{'HostID'}");
push(@msgLines, "OrgID = $config{'OrgID'}");
push(@msgLines, "SrcDirection = $config{'SrcDirection'}");
push(@msgLines, "DstDirection = $config{'DstDirection'}");
push(@msgLines, "AlarmLevel = $config{'AlarmLevel'}");
push(@msgLines, "SigID = $config{'SigID'}");
push(@msgLines, "SigName = $sigName");
push(@msgLines, "SubSigID = $config{'SubSigID'}");
push(@msgLines, "ProtocolType = $config{'ProtocolType'}");
push(@msgLines, "SrcIpAddr = $config{'SrcIpAddr'}");
push(@msgLines, "DstIpAddr = $config{'DstIpAddr'}");
push(@msgLines, "SrcIpPort = $config{'SrcIpPort'}");
push(@msgLines, "DstIpPort = $config{'DstIpPort'}");
push(@msgLines, "RouterIpAddr = $config{'RouterIpAddr'}");
push(@msgLines, "AlarmDetails = $config{'AlarmDetails'}");
push(@msgLines, "MsgCount = $config{'MsgCount'}");
sendEmail(@msgLines);
debug("done");
# parse the signatures file and store in the %signatures hash
sub parseSignatures
local $sigId, $sigName;
open(INSIG, "<$config{'signatures-file'}") || warn "unable to open signatures file($config{'signatures-file'})\n";
while() {
# skip commented lines
if(/^\s*#/) {
next;
# the signatures are in the following format:
# sigId "signature name"
# where sigId is an integer
if(/^\s*(\d+)\s+\"([^\"]+)\"/) {
$sigId = $1;
$sigName = $2;
$signatures{$sigId} = $sigName;
close(INSIG);
# send the given string array as email
sub sendEmail
local(@msgLines) = @_;
debug("sending email");
debug("To: $config{'email-to'}");
debug("From: $config{'email-from'}");
debug("Subject: $config{'email-subject'}");
debug("Reply-To: $config{'email-reply-to'}");
$smtp = Net::SMTP->new($SMTP_Server); # connect to an SMTP server
$smtp->mail($config{'email-from'}); # use the sender's address here
local(@recipients);
local($to);
# split the recipients on spaces and commas
@recipients = split(/,\s/, $config{'email-to'});
# tell smtp about each recipient
foreach $to (@recipients) {
$smtp->to($to); # recipient's address
$smtp->data(); # Start the mail
# Send the header.
$smtp->datasend("To: $config{'email-to'}\n");
$smtp->datasend("From: $config{'email-from'}\n");
$smtp->datasend("Subject: $config{'email-subject'}\n");
$smtp->datasend("Reply-To: $config{'email-reply-to'}\n");
$smtp->datasend("\n");
# Send the body.
foreach $line (@msgLines)
debug($line);
$smtp->datasend("$line\n");
$smtp->dataend(); # Finish sending the mail
$smtp->quit; # Close the SMTP connection
# debug print statement
sub debug
local($str) = @_;
if($config{'debug-level'} > 0) {
print "$str\n";
Can I ask one question regarding this problem ?
Why I don't have this folder :
I tried to find in the directory where I installed CSPM.. I could not find it thanks
Bernhard,
Thank you, it looks like what I need, but I can't get it to work. I got perl and email working with a test script, but with your script I get an error: Unterminated <> operator at d:\temp\CSPM\emailEvent.pl line 46
Can I open a TAC case with you to get this notification script working? How?
Also, can you demonstrate how to get Signature Name into the subject line?
I would have an other wish! I want to see the nslookup resolution names instead of IP address! It is possible? Will this features included in the following versions?
Thanks!
Had trouble with that script. I tweaked it. If you want a copy email me dmorone@courts.state.ny.us . I can't post it here because the forum won't accept the big post.
I've got it sending me email that looks like this:
To: <me@my.com>
Date: 11/20/01 11:26AM
Subject: SensorName - SigName - AlarmDetails
Date Time
Source: IP:port Destination: IP:port
Signature: SigID:SubSigID SigName AlarmDetails MsgCount
Don't email me. Get it here:
http://www.burdenlake.org/ids/emailEvent.pl
119
