Community Member
CSPM versus IDM/IEV
Does anybody know what the future of CSPM will be?
Is it a good choice to switch to IDM/IEV or shall we continue to work with the CSPM?
Best regards
Paul Knoll
Community Member
Re: CSPM versus IDM/IEV
it depends :-)
For configuring the sensor, IDM is more powerfull than CSPM thanks it's ability to fine tune the sensor.... It's very easy.
For monitoring, if you have only 3 devices or less, i would propose IEV. Why ? because IEV provide some nice features like 'acknowledgment' of alarms, multiple view and IEV provides a stable database (MySQL). This also provides a way to write your own SQL queries and execute report against the DB
If you have more IDS... no choice, wait for IDS-MDC
CSPM or the Unix Director are still the recommended tools when configuring and monitoring more than 3 sensors.
IDM/IEV are meant for small 1 to 3 sensor deployments.
If you like the additional functionality of IDM, but have more than 3 sensors, then you can use IDM for configuration, and CSPM (or Unix Director) for alarm viewing for now.
For the future of IDS Management Tools for the Enterprise (i.e. more than 3 sensors) then please contact your Cisco Representative.
104
