CSPM Wan Interfaces
Does the CSPM Network Topology cater for two Wan Interfaces(to the ISP) on the same router.
Re: CSPM Wan Interfaces
The focus of this board is Virtual Private Networks, however, there are a number of professionals online who may be able to assist you.
We are always considering additional forums for such topics and I will make a note of your post.
If you don't get a suitable response to your post, you may wish to look at the product information at http://www.cisco.com/go/policymanager
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
CSPM does cater to two WAN interfaces on the same router to a single upstream ISP.
First when you build the router into the network topology, (say by topology wizard) then CSPM learns all the interfaces. Then build your internal network under one of the interfaces. Under the second interface build a shortcut-to-the-firstinterface. I tried this for two routers coming onto single firewall successfully. But it should also do for a single router with two interfaces to a single ISP.
BoL
138
