Custom Sig to Alarm on a Specific IP
Hello All,
I have a Windows 2K server that was compromised recently and I know the bad guy's IP address. Is there a way to configure my 4230 to alert using a custom signature when the bad guy's IP address enters my network? Any help will greatly be appreciated. Thanks
Bronze
Re: Custom Sig to Alarm on a Specific IP
Here's a possible solution. Be forewarned though. Using this technique will likely cause a significant perfomance impact to your sensor. First, create a custom signature that looks like this:
Tune Signature Parameters : CSIDS Signature Wizard
___________________________________________________________________________
Current Signature: Engine ATOMIC.L3.IP SIGID 20000
SigName: Bad Guy IP
0 - Edit ALL Parameters
1 - AlarmInterval =
2 - AlarmThrottle = FireAll
3 - ChokeThreshold =
4 - FlipAddr =
5 - isIcmp =
6 - isOverrun =
7 - LimitSummary = True
8 - MaxDataLen =
9 - MaxInspectLength =
10 - MaxProto =
11 - MaxReassembledLen =
12 - MinDataLen =
13 - MinHits =
14 - MinProto =
15 - MinReassembledLen =
16 - ProtoNum =
17 - ResetAfterIdle = 15
18 - SigComment =
19 - SigName = Bad Guy IP
20 - SigStringInfo =
21 * StorageKey = GLOBAL
22 - ThrottleInterval = 30
23 - WantFrag =
d - Delete a value
u - UNDO and continue
x - SAVE and continue
Second, create a RecordOfExcludedPattern like this:
RecordOfExcludedPattern 20000 * /32 *
Bronze
One of our crack Q/A engineers noticed an error in my previous reply. The correct filter should be:
RecordOfExcludedPattern 20000 * * *
RecordOfIncludedPattern 20000 * *
Thanks a lot! I will give it a go.
Couldn't you just use the RecordOfLogAddress W.X.Y.Z 255.255.255.255 ?
RecordOfLogAddress would create an IPLOG for all packets to and from the address, but it won't generate an alarm.
109
