CW2K install problem
Hello.
I put in CD ONE (4th Edition) and selected the "typical install". About half way thru the install, I get the following error message...
DNS check has failed for one of the following reasons:
* Your DNS is not working.
* Your DNS is slow.
* The hostname of this server is not in DNS.
How do I resolve this??
I can get to the web just fine. I can also perform nslookup's just fine. So, I assume DNS is
working.
Any thoughts??
Blue
Re: CW2K install problem
Have a look at CSCdu15005. If your DNS is working properly in both directions, you can ignore this message.
Hi. Thanks for the response..
What is CSCdu15005? Where can I find it to look at??
Thanks.
Blue
Use CCO Bug ToolKit for this
93
