Community Member
default contexts onn FW module 6500 for TESTING purposes?
"2 Virtual Firewalls and 1 administrative context are provided for testing
purposes"
THE ABOVE STATEMENT IS COMING FROM THE DATASHEET OF FW MODUTE FOR 6500.
DOES THIS MEAN THAT THE 2 CONTEXT WILL NOT WORK IN PRODUCTION?
THANKS
Hall of Fame Super Blue
Re: default contexts onn FW module 6500 for TESTING purposes?
No, as far as i am aware you can use them in production if you like. There is no license expiration. Basically you get 2 contexts + 1 admin context with the FWSM and you can use these any way you like.
Jon
Community Member
hello,
That "testing purposes" is realy a confusing thing. Could anyone from cisco reconfirm this please.
116
