Delay opening VPN with Client 4.0.3 C
I've noticed that since installing 4.0.3C VPN client that new connections ocasionally take around 30 seconds to open a VPN to a PIX. Interestingly, the second and subsequent connections usually proceed quickly.
The log on the client shows this at the pause:
77 14:36:15.423 01/15/04 Sev=Info/6 CM/0x63100036
The routing table was updated for the Virtual Adapter
78 14:36:42.682 01/15/04 Sev=Info/4 CM/0x6310001A
One secure connection established
Anyone seen this?
Silver
Re: Delay opening VPN with Client 4.0.3 C
We are using Client 4.0.3 A and did not see any problems. I think one possibility is that you have some sort of a dial up or ISDN connection that needs to get established first. Once that is done, the clients that connect subsequently do not need to wait for this and connect immdiately.
Nope, seen this behavior with T1 and even with directly attached ethernet. I didn't see it in 4.0.3A either, I think it's a new issue in 4.0.3 C.
159
