Delete Sensor Signature From CSPM
I am trying to delete an unused Signature Template from CSPM. I have tried renaming it and deleting it and this doesnt work. I have used Tools --> Find and it only finds the one instance. When I try to delete it I get : "This item or one of its descendants is currently being referenced by other items, and therefor cannot be deleted until such references are removed. TOOLS FIND can be used to locate references." But there isnt any references.
Re: Delete Sensor Signature From CSPM
Has the template you are trying to delete been applied to any sensor? That may be the issue.
it has been applied to a sensor before, in the past. but i made a new one and the sensor looks to the new one now. i have checked and no sensors look tp this file.
I've had the same issue. I sent Cisco my CSPM file, and they couldn't delete that signature set. Finally, I had to reset my initial CSPM config and rebuild it. Hope this helps!
103
