Deploy job wont run; Can't delete it either
A deploy job for a sensor seems to be stuck. It wont run and if I try to delete it I get "Delete of deploy job failed, fatal exception caught.DBFieldManager:A non-database exception occurred while trying to load the object. " No other deploy jobs will run either. How can I get rid of this job?
Silver
Re: Deploy job wont run; Can't delete it either
Try re-adding the deleted device, then delete the changes and then remove the device. If that doesnot work, try reloading the VMS server.
Rebooting the server usually works. I would think that stopping and starting the appropraite services would also do the trick.
82
