Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Bronze
des versus 3des
hi
i would like to have an explanation about des and 3des, so my question
is does des use 56 bit form encryption or 64 bit ? i saw somewhere that the 8 bit in difference are used for parity is that true?.
my second question what is the lenght in bit of the block' s message on it des and 3des act to provide encryption?
thanks in advance
any suggestion ,advice ,would be great
Re: des versus 3des
You got it you are only using 56 bits for actual encryption. Triple des is just takeing the packet you encrypted and running the encryption algorithem twice more.
I really couldn't say much about your second question.
Patrick
Gold
Re: des versus 3des
Yes des is using 56 bit key
3 des doesnt mean 3x encrypttion but
3des uses 3 different keys following:
by 1st key message is encrypted than this encrypted message is decrypted with second key and finally encrypted again with 3rd key - its much more secure than simply 3x encrypted message
89
