Community Member
dhcprelay with vlans
I'm trying to get dhcprelay
to work, forwarding from an
inside i/f to a dhcp server beyond the outside i/f.
This works fine when the inside i/f is an access link, e.g. untagged to the next level switch.
When I convert the inside i/f
to a virtual i/f via vlan tagging, the dhcprelay quits working.
A packet capture on the outside i/f shows the request being forwarded, and the reply coming
back. However a capture on the virtual inside i/f never shows the reply packets from the dhcp
server.
This is on a PIX515 running 6.3(4). Here are the pertinent config lines. Any ideas appreciated, I don't want to have to put an additional card into the box if I can avoid it.
thanks,
Peter
interface ethernet1 vlan4000 physical
interface ethernet1 vlan812 logical
nameif ethernet1 tos-trunk security98
nameif vlan812 wlanguest security99
ip address wlanguest X.X.X.X 255.255.248.0
no failover ip address wlanguest
nat (wlanguest) 0 X.X.X.0 255.255.248.0 0 0
static (wlanguest,outside) X.X.X.0 X.X.X.0 netmask 255.255.248.0 0 0
access-group acl_in in interface wlanguest
dhcprelay server Y.Y.Y.Y outside
dhcprelay enable wlanguest
1 REPLY
Silver
Re: dhcprelay with vlans
what is the inside vlan here we are talking about?
what is the native vlan set on the switch?
Any syslog messages being generated?
thanks
Nadeem
281
