Difference b\w Pre-Shared and Pre-Shared(X-Auth)
when you configure a group on VPN 3005, you have the option of selecting the IKE proposal with either 1). Pre-Shared Key OR 2)- Pre-Shared (with X-Auth).
What is the difference between these two ?
When i configure either of these, i don't notice a difference when dialing using the Cisco VPN Client.
Regards \\ Naman
1 REPLY
Re: Difference b\w Pre-Shared and Pre-Shared(X-Auth)
Hi Naman,
Pre-shared keys are used between 2 routers when you want to create LAN-to-LAN VPN connection. Pre-shared (with X-auth) is used between a router and a VPN client. X-auth requires user and group authentication of the connecting unity client peers through some mechanisms like AAA server.
If you are using a head-end router to allow both site-end routers and remote VPN client peers to establish VPN tunnels, then the head-end router should be configured with both Pre-shared key and Pre-shared key (with X-auth); one for the LAN-to-LAN tunnel peer and the other for the unity client peer.
You can also refer to the following link
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094685.shtml
Hope this answered your question.
Warm regards,
Naveen
mnaveen@cisco.com
134
