Difference between AIM-VPN/EPII and AIM-VPN/HPII
Can any body tell me the difference between the 2. I am trying to decide on which router model to purchase, 3625 or the 3645 VPN bundle and I cannot find the difference documented any where.
Re: Difference between AIM-VPN/EPII and AIM-VPN/HPII
Obviously these are both hardware encryption cards for the 3600 series.
The EPII is rated up to 150Mb/s 3DES throughput with a maximum of 2000 tunnels. It is only for the 3725 router running at least 12.2(13)T.
The HPII is rated up to 180Mb/s 3DES throughput with a maximum of 2000 tunnels. It is for the 3660 and 3745 routers running at least 12.2(13)T.
You mentioned you're purchasing either a 3625 or a 3645, I presume you mean 3725 or 3745.
Yes, I did mean 3725 or 3745. Thank you for your response. It is clear to me now.
133
