Difference between protocol object group and service object group?
What is the difference in defining a protocol object group as oppossed to a service object group? They both appear to open up specific ports for an application. Why use one rather than the other?
Re: Difference between protocol object group and service object
The protocol object group is used to specify a protocol(s) to be defined in an ACL or conduit. This object group can be used as the protocol type only in the associated ACL or conduit.
The service object group is used to specify specific or ranges of TCP and/or UDP ports to be defined in an ACL or conduit. This object group can be used as either the source port(s) or destination port(s) in the associated ACL/conduit
More info / examples on the below url;
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_tech_note09186a00800d641d.shtml
Hope this helps,
Yatin
As I understand, we can simply define them as:
Protocol object-group- layer 3 (to define protocols like ip, esp, gre etc)
Service object-groups - layer 4 (to define port numbers under tcp, udp or both)
Best regards / Sampath.
Srengarajan@att.com
664
