different port numbers for the same application
hi
Is that possible to configure 2 different number for the same protocols.i.e there is a fixup command we use in pix firewall:
fixup protocol http 80
fixup protocol http 8090
can somebody tell me whether we can use 2 diferrent port numbers for the same application or not and in what circumstances?
Re: different port numbers for the same application
I assume you are referring to PIX OS 7.x.
If so, simply modify your class-map to map whatever ports you want. Then apply apply your inspection rule to that class-map inside of your policy-map.
class-map my-app
match-port tcp 80
match-port tcp 8090
policy-map my-map
class my-app
inspect http
service-policy my-map interface myinterface
This should allow you to accomplish what you want. You can get very specific with the class-map and have it only apply to certain traffic based on access lists. Check out the PIX OS 7.x documentation for more, but I think this will get you started.
yes, I am using pix OS 7 version. But I would like to know in what circumstances we will be using different port numbers for the same protocol/application? Are we providing extra security by using different port numbers?
Sometimes changing the default port does provide for extra security because "kiddie scripters" and botnets may not automatically detect an open port, especially if it's a port of non-interest.
Other times, certain types of HTTP servers and other services run on different IP ports. For example, Apache Tomcat will often run on 8080, Vmware ESX HTTP console runs on 8222, Symantec AV for Exchange HTTP console runs on 8081, etc, etc.
There's also another reason, and that's for PAT. If you have a limited number of external IP addresses. For example, you can port forward outside address 169.90.9.1:80 to internal 192.168.1.1:80 and at the same time forward 169.90.9.1:8888 to 192.168.1.2:80. This way, you are able to publish two internal, physical web servers with only one external IP address. Of course, the :80 port identifier is not necessary in the URI since that is the default HTTP port, but it's included for clarification.
Thanks for your reply. I got it now.
Does PIX supports PAT when me create PIX-TO-PIX Ippsec tunnel. Becuase when we create the tunnel all data gets encrypted including header and payload. My quesion is that how does it maintain the uniformity between the different port numbers? Do we need to disable NAT/PAT before creating the tunnel? There is a confusion.....
Can you please explain me?
Vin
My earlier statements were for non-tunneled traffic only (i.e., originating from the internet.)
It is common practice to disable NAT/PAT when creating IPsec tunnels between PIX firewalls. You can do this with the nat 0 statement. For example,
nat (inside) 0 access-list nonat
You would then create an access list for the traffic that you do not want to NAT (the ipsec traffic).
access-list nonat permit ip 192.168.1.0 255.255.255.0 172.16.1.0 255.255.255.0
Where 192.168.1.0 is your local network and 172.16.1.0 is the remote network. You would do the reverse the access-list statement on the other PIX.
It is also common practice to enter the following command:
sysopt connection permit-ipsec
That command will let the VPN traffic bypass the access lists configured for regular traffic. In this way, you don't have to create access lists like:
access-list outside2inside permit ip 172.16.1.0 255.255.255.0 192.168.1.0
Thanks, yeah it has been resolved.I appreciate it
vin
111
