Community Member
Disabling inactivity timeout
I wish to disable or at least significantly increase the inactivity timer of a telnet session to a 3560. How is this done?
At present, if no commands are typed then after a few minutes the telnet session is automatically closed.
Many thanks
Tony
1 ACCEPTED SOLUTION
Gold
Re: Disabling inactivity timeout
line vty 0 4
exec-timeout 0
that sets it to never expire.
or
exec-timeout 10 30
which sets it to expire after 10min 30s of idle time. you get the idea.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1826/products_command_reference_chapter09186a00800d9c35.html#xtocid26729
Gold
line vty 0 4
exec-timeout 0
or
exec-timeout 10 30
Community Member
Tremendous, that's done the trick.
Many thanks
4587
