Disabling Secure Services Client System Tray Notification Balloons
I would like to disable the balloons that the Secure Services Client (SSC) displays in the System Tray when user authentication is required and have the logon prompt appear without user intervention. Apparently this can be achieved by turning off the "Enable system tray notifications" option but I can't find this option. I assume it should be added to the configuration.xml file but I'm not sure which part of the XML tree it should be added to and what the property name is.
123
