Division local users for vty and other needs
rpoznyak
HI!
I have two local users
username vty pasword blablabla
username vpdn password blablabla
aaa new-model
aaa authentication login default local
How to disable local login to vty-line for user vpdn(using just for vpdn-tunnel authentication) and enable this for user vty(using just for login to the router) without using AAA-protocols(Tacacs, Radius).
Patrick Laidlaw
Level 4
Level 4
I don't think you have the ability to block one user vs another from loging into the VTY terminals when using "login local". You can add an access-class that will define where a user can connect from to login to the VTY terminals.
Patrick
