09-24-2007 12:32 PM - edited 02-21-2020 03:17 PM
I had a configuration with "IP NHRP" the protocol for next hop resolution, in this environment I have 18 routers in Full meshed VPN connection. Now if from an spoke router I ping the tunnel interface of other router a nex crypto session is stablished, but IF an internal host ping a host that is behing the other router all traffic goes through the HUB. What still make my topology as hub-and-spoke and not full mesh.
Anyone has ever done that before?
09-28-2007 02:31 PM
The IP address of the destination device to which connectivity must be maintained from the primary VPN interface connection. This is the device that is pinged by the Service Assurance agent through the primary route to track connectivity. The backup connection will be triggered if connectivity to this device is lost. Note If you do not specify an IP address, the primary hub VPN interface will be used in a hub-and-spoke VPN topology. In a point-to-point or full mesh VPN topology, the peer VPN interface will be used
10-01-2007 04:28 AM
Thank you for the answare, but what I needed to do was issuing the :
no ip next-hop-self eigrp 1
Command.
