DMVPN hub and spoke at the same box
Hi, guys,
Have you ever tried to config a box as a DMVPN hub and another DMVPN spoke at the same time? It seems that this may resule in some problems in my environment. The spoke feature can work well, but the Hub feature has some issues for me.
This Hub can't always have good ike sa with its spoke. And always tell me that there are invalid spi errors.
someone experienced this? Thank you in advance!
Ed
1 REPLY
Re: DMVPN hub and spoke at the same box
Hi,litouch,
We are facing the same issue.Although my environment is something different from you.Actually i need two router act as hub service for separate user,but i only got one 7206vxr, so it must act as hub for separate user at the same time.
Then i create two tunnel on the 7206,and i also facing "invalid spi errors".Only one tunnel can work normally.
I couldn't fixed the problem yet.
121
