Community Member
DMVPN problem
I am having a problem with Dynamic Multipoint VPN on a group of 2800 series routers.
The tunnels between the spokes and hub work fine, but the dynamic tunnels between the spokes do not come up with normal traffic. I can cause the tunnels to be created if I ping the tunnel interface from one spoke to the other.
Your help is appreaciated.
Andy
Hub
crypto isakmp policy 1
authentication pre-share
crypto isakmp key vpnr3mot3 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set dmvpn esp-3des esp-sha-hmac
crypto ipsec profile vpnprofile
set security-association lifetime seconds 28800
set transform-set dmvpn
interface Tunnel0
description Multi-Point GRE
ip address 10.200.200.1 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp authentication r3mot3
ip nhrp map multicast dynamic
ip nhrp network-id 100
ip ospf network broadcast
tunnel source Multilink1
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile vpnprofile
router eigrp 100
redistribute connected
redistribute static
network 172.21.0.0
network 192.168.100.0
network 0.0.0.0
no auto-summary
router ospf 1
log-adjacency-changes
network 10.200.200.0 0.0.0.255 area 0
network 192.168.100.0 0.0.0.255 area 1
Spoke 1
crypto isakmp key xxx address 0.x.x.x.0.0.0
set security-association lifetime seconds 120
interface Tunnel0
ip address 10.200.200.4 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp map 10.200.200.1 172.21.11.10
ip nhrp map multicast 172.21.11.10
ip nhrp nhs 10.200.200.1
ip ospf priority 0
tunnel key 0
router eigrp 100
redistribute static
network 10.131.50.0 0.0.0.255
network 172.20.0.0
no auto-summary
router ospf 1
network 10.131.50.0 0.0.0.255 area 0
network 10.204.204.0 0.0.0.255 area 0
Spoke 2
interface Tunnel0
ip address 10.200.200.2 255.255.255.0
no ip redirects
ip mtu 1440
ip ospf priority 0
tunnel key 0
router eigrp 100
network 172.20.0.0
network 192.168.103.0
no auto-summary
router ospf 1
network 192.168.103.0 0.0.0.255 area 0
Community Member
Re: DMVPN problem
This wizard will help you configure your router as a DMVPN hub. The hub should be configured before the spokes so that you can provide the spoke administrators with the information they need to configure their spoke routers.
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_user_guide_chapter09186a0080511c22.html
Silver
Re: DMVPN problem
At the spoke see if the foll changes helps
no ip nhrp map multicast dynamic
Community Member
Re: DMVPN problem
So basicly we add IP nhrp map multicast for each spoke?
I thought the hub was supposed to handle this dynamicly
Silver
Re: DMVPN problem
Well the hub actually resolves the next hop not multicast nexthop if iam correct. I ran into the same problem and had to do this as a workaround
Community Member
Re: DMVPN problem
Andy,
If spoke-to-spoke tunnels are required, the no ip next-hop-self eigrp command,
introduced in Cisco IOS Software Releases 12.3(2) and 12.2(13)T, must be configured on the hub mGRE
tunnel interface to tell EIGRP to use the original IP next hop when advertising these routes.
This should fix your problem with the spoke to spoke tunnels.
David
Community Member
Re: DMVPN problem
Sorry my bad! I see your using OSPF and have broadcast configured.
151
