DMVPN problem
HUB tunnnel:
bandwidth 16000
ip address 10.0.6.9 255.255.255.248
no ip redirects
ip mtu 1400
ip nhrp authentication xxx
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 600
ip tcp adjust-mss 1360
delay 1000
tunnel source FastEthernet0
tunnel mode gre multipoint
tunnel key 1
tunnel protection ipsec profile DMVPN
Spoke tunnel:
bandwidth 6000
ip address 10.0.6.11 255.255.255.248
no ip redirects
ip mtu 1400
ip nhrp map 10.0.6.9 xx.xx.xx.xx
ip nhrp map multicast xx.xx.xx.xx
ip nhrp nhs 10.0.6.9
delay 1000
tunnel source Vlan2
tunnel key 1
On HUB and Spoke:
crypto isakmp policy 5
encr aes 256
authentication pre-share
group 2
crypto isakmp key xxx address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 15 5 periodic
crypto ipsec transform-set VPNSET esp-aes 256 esp-sha-hmac
crypto ipsec profile DMVPN
set transform-set VPNSET
sh dmvpn command from spoke:
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 XX.XX.XX.XX 10.0.6.9 IPSEC never S
sh dmvpn command from HUB
returns only legend :o((
do you have any suggestion?
  • Other Security Subjects
1 REPLY
Re: DMVPN problem
What is the problem you are facing? Is your tunnel not coming up.
Make sure that you are using transport mode.
mode transport
sh cry isa sa
sh ip nhrp
sh ip nhrp dynamic
These are some of the commands that will tell you the status of the tunnel.
Please rate this post, if it helps
Cheers
Gilbert
178
