DMZ Access List To Inside Network Problem
Running PIX 525
Cisco PIX Firewall Version 6.2(2)
Cisco PIX Device Manager Version 2.0(2)
I'm having some strange access problems from the DMZ to the internal network. This problem started about a week ago. I have several ports opened from my DMZ to my inside network (SMTP, FTP)
Some access list are working while some ports that were working stopped. Listed below is the DMZ access list. Any help would be grateful!!!
access-list DMZ permit icmp any host 172.16.2.22 echo-reply (hitcnt=4)
access-list DMZ permit icmp any host 172.16.2.34 echo-reply (hitcnt=8)
access-list DMZ permit icmp any host 172.16.2.24 echo-reply
access-list DMZ permit udp any host 172.16.2.1 eq domain
access-list DMZ permit icmp any host 172.16.2.15 echo-reply
access-list DMZ permit icmp any host 172.16.2.27 echo-reply
access-list DMZ permit tcp any host 172.16.2.27 eq smtp
access-list DMZ permit tcp host 192.168.1.7 any eq www
access-list DMZ permit tcp host 192.168.1.7 any eq ftp
access-list DMZ permit tcp any host 172.16.2.34 eq smtp
access-list DMZ permit tcp any host 172.16.2.29 eq ftp
1 REPLY
dro
Re: DMZ Access List To Inside Network Problem
Perhaps you should take a look at your system logs for any errors that are causing you problems. If you don't have system logs enabled, use these commands:
logging on
logging buffered warnings
If you have packets that are being blocked by your access lists, they will show up in the log as follows:
106023: Deny tcp src dmz:a.a.a.a/port dst inside:b.b.b.b/port by access-group "DMZ"
If the problem isn't related to the access lists, you should see some other type of error messages describing why the connection was blocked.
-Joshua
111
