dmz static issue
I have one host in a dmz that I allow to access a host on our internal lan, static (inside,outside) 192.168.10.3 192.168.51.2 netmask 255.255.255.255.
I know have a second host, 192.168.51.3, that I would like to allow 192.168.10.3 to access. I know I cannot apply the following static, static (inside,outside) 192.168.10.3 192.168.51.3 netmask 255.255.255.255, as it will create a conflict with the first static.
What is the best way to accomplish what I am trying to do? I think I am missing something really simple.
Thanks.
1 ACCEPTED SOLUTION
Silver
Re: dmz static issue
Based on the way your scenario sounds what you need is:
static (inside,outside) 192.168.10.0 192.168.51.0 netmask 255.255.255.0
and then use acl on outside interface like:
access-list acl_in permit ip host 192.168.10.3 host 192.168.51.2
access-list acl_in permit ip host 192.168.10.3 host 192.168.51.3
HTH pls rate!
1 REPLY
Silver
HTH pls rate!
88
