DMZ VPN Issue
Hello all,
Good Day,
I have two Cisco PIX 525 OS 7.0(1) both are configured as failover Active/Standby mechanism. I added a layer 2 switch and configured 3 VLANs in it. One Vlan (192.186.20.x as a real ip) is connecting both the outside interfaces (eth0) and the ISP router. Other Vlan (10.11.0.0) is connecting both the DMZ interfaces (eth3) and a VPN router configured as site-to-site with branch offices routers. Third Vlan (16.0.0.0) is connecting both the inside interfaces (eth1) to the backbone switch (Cat.4510R). In addition,two servers (web and mail) are connected to the DMZ Vlan with the PIX DMZ interfaces.
My scenario is to provide internet connectivity to those servers as well as VPN connectivity throught the PIX. When i configure the Active PIX's DMZ interface as the default gateway of those servers, they are browsing the internet very well. I added 9 static routes in the pix to reach the remote VPN peers through the VPN router on the DMZ and the PIX see them well and ping them. However,the DMZ servers do not see them well. I want to make those DMZ servers to see the branch offices VPN tunnel through the pix.
I can simply set the VPN router's DMZ interface as the default gateway of those servers but when i do that, the internet connectivity goes down and the servers see the remote offices well without passing through the pix.
The VPN router is 10.11.0.1
i want to make the servers to see the internet as well as the VPN tunnel through pix.
Check This!
PIX Version 7.0(1)
names
interface Ethernet0
description outside public networks
nameif outside
security-level 0
ip address 192.186.20.200 255.255.255.0 standby 192.186.20.201
interface Ethernet1
description inside private networks
nameif inside
security-level 100
ip address 16.1.x.x.255.0.0 standby 16.1.1.254
interface Ethernet2
description STATE Failover Interface
interface Ethernet3
description DMZ network
nameif DMZ
security-level 50
ip address 10.11.0.250 255.255.255.0 standby 10.11.0.251
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
access-list incoming extended permit tcp any host 192.186.20.12 eq www
access-list incoming extended permit tcp any host 192.186.20.12 eq https
access-list incoming extended permit tcp any host 192.186.20.12 eq smtp
access-list incoming extended permit tcp any host 192.186.20.12 eq pop3
access-list incoming extended permit tcp any host 192.186.20.12 eq domain
access-list incoming extended permit tcp any host 192.186.20.13 eq www
access-list incoming extended permit tcp any host 192.186.20.13 eq https
access-list incoming extended deny ip any any
failover
failover polltime unit msec 500 holdtime 3
failover key *****
failover replication http
failover link statefullink Ethernet2
failover interface ip statefullink 10.10.10.1 255.255.0.0 standby 10.10.10.2
global (outside) 1 192.186.20.250 netmask 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
static (DMZ,outside) 192.186.20.12 10.11.0.12 netmask 255.255.255.255
static (DMZ,outside) 192.186.20.13 10.11.0.13 netmask 255.255.255.255
access-group incoming in interface outside
route outside 0.0.0.0 0.0.0.0 192.186.20.10 1
route inside 10.2.0.0 255.255.0.0 10.2.1.1 1
route inside 10.3.0.0 255.255.0.0 10.3.1.1 1
route inside 10.4.0.0 255.255.0.0 10.4.1.1 1
route inside 10.5.0.0 255.255.0.0 10.5.1.1 1
route inside 10.6.0.0 255.255.0.0 10.6.1.1 1
route DMZ 10.11.9.0 255.255.255.0 10.11.0.250 1
route DMZ 10.11.8.0 255.255.255.0 10.11.0.250 1
route DMZ 10.11.7.0 255.255.255.0 10.11.0.250 1
route DMZ 10.11.6.0 255.255.255.0 10.11.0.250 1
route DMZ 10.11.5.0 255.255.255.0 10.11.0.250 1
route DMZ 10.11.4.0 255.255.255.0 10.11.0.250 1
route DMZ 10.11.3.0 255.255.255.0 10.11.0.250 1
route DMZ 10.11.2.0 255.255.255.0 10.11.0.250 1
route DMZ 10.11.1.0 255.255.255.0 10.11.0.250 1
Re: DMZ VPN Issue
This is the problem in the design.
You should probably look at moving the servers to a separate DMZ interface.
-VJ
Re: DMZ VPN Issue
PIX can't route traffic back out the same interface it received the traffic on. Not sure about 7.0(1).
Re: DMZ VPN Issue
Set the VPN router's DMZ interface as the default gateway of those servers.
Then add a default route which directs all traffic to the internet to your outside interface.
Something like
route DMZ 0.0.0.0 0.0.0.0 192.186.20.x 1
Folks ,please correct me if I am wrong.
199
