DNS fixup not working on PIX 501 6.3
info
Hi all,
I am running a PIX 501 FW and everything is fine except for one thing. We have a DNS server on the inside and according to the docs the dns fixup setting shold translate A records automatically so they have "outside" IP adresses when viewed from the outside although they are actually configured on the DNS server with "inside" IP's.
However it doesn't work. If I eg. query the DNS server for ns.my.com it returns 10.195.0.1 and not x.x.x.x as I would have expected.
Is my configuration wrong or doesn't that work at all?
Excerpt of config:
fixup protocol dns maximum-length 2048
static (inside,outside) x.x.x.x 10.195.0.1 netmask 255.255.255.255 0 0
nkhawaja
i dont think this is what dns fixup is for.
try this
static (inside,outside) x.x.x.x 10.195.0.1 netmask 255.255.255.255 dns
nkhawaja
try this
Ah yes, that was exactly what was needed. I thought I had read the docs, but not enough apparently - I had missed the "dns" option on static.
Thank you very much!
