DNS lookups for MX records fail through PIX
I have an SMTP gateway in a DMZ. When I query MX records using UDP for certain domains using my internal DNS server as the DNS server the responses fail on certain domains that have large responses. My initial thoughts are that the DNS UDP packets are larger than 512bytes. Matter of fact I'm almost positive that is the problem. I've tried resolving this by increasing the size of the DNS fixup but it doesn't work. Has anyone seen this before? Any ideas? By the way, from inside my network querying the MX records for some of those domains using the same DNS server the response comes back fine, it's just from the DMZ that this fails. And, if I allow TCP into the DMZ for DNS the SMTP server reverts to using TCP and it works.
Re: DNS lookups for MX records fail through PIX
trying issue the command:
no fixup protocol DNS
Thanks, but I did that and I still can't get a response using UDP. Starting to think I might have a buf in the PIX code.
Oh, I meant bug not buf: fat fingers. By the way UDP queries for domains that have short responses work fine.
Actually, you may want to do the command:
fixup protocol dns maximum-length 2048
This should resolve your issue. I'm guessing you have Windows 2003 DNS servers?
151
