DNS on inside
I have three lan (inside) 192.168.0.0/24 , outside 172.16.10.0/24 where there is router Internet and DMZ 172.16.11.0/24.
My customer has posted his WEB server from inside to DMZ with address 172.16.11.151.
This WEB server is also his Mail server and Lotus server.
With appropriate policies on Pix 515 all it works in order from outside and from inside users.
There is only one problem that from inside user he can see his WEB server as machine when he browse his network how neighbour from Windows.
There isn't nat from neither interfaces and with an specific access-list he can ping from inside network the host 172.16.11.151.
What can be?
thanks
Lorenzo
Silver
Re: DNS on inside
If his web server also runs other services, and can be seen in network neighborhood, its possible that someone opened up way too many ports from the dmz and into the internal network. can you post the pix config?
Re: DNS on inside
Here is
wr t
Building configuration...
: Saved
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list acl_out permit tcp any host 172.16.11.151 eq www
access-list acl_out permit tcp any host 172.16.11.151 eq smtp
access-list acl_out permit tcp any host 172.16.11.151 eq lotusnotes
access-list acl-out permit icmp any any
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 172.16.10.1 255.255.255.0
ip address inside 192.168.0.1 255.255.255.0
ip address dmz 172.16.11.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
nat (inside) 0 192.168.0.0 255.255.255.0 0 0
nat (inside) 0 192.168.0.0 255.255.0.0 0 0
nat (dmz) 0 172.16.11.0 255.255.255.0 0 0
static (dmz,outside) 172.16.11.151 172.16.11.151 netmask 255.255.255.255 0 0
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 172.16.10.2 1
route inside 192.168.0.0 255.255.0.0 192.168.0.202 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS protocol tacacs
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 192.168.0.99 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:fe3ed8aaedb01e172072446839fa60ad
: end
[OK]
95
