DNS query problem in FWSM
Hi, Thanks for this information.
We have a unique problem in our network. DNS queries are not resolving intermittently. Everything works fine for a day. And suddenly nobidy can able to connect to the internet. Once we issue command "Clear xlate" on the FWSM we are able to go to the internet for one more day. We have FWSM as our firewall and all the hosts inside the network are PATed. Our internal DNS Server is pointed to the outside DNS server 4.2.2.2 for outside queries. So for every queries internal DNS will send the query to the outside DNS. This is the setup.
During the problem, we captured the Connections in FWSM by
"Sh conn" command
it shows lots of following DNS connections
UDP out 4.2.2.3:53 in 172.16.5.28:3869 idle 0:00:42 Bytes 36
FLAGS - D
UDP out 4.2.2.1:53 in 172.16.5.29:1869 idle 0:00:50 Bytes 36
FLAGS - D
UDP out 4.2.2.3:53 in 172.16.5.28:3869 idle 0:01:12 Bytes 36
FLAGS - D
UDP out 4.2.2.1:53 in 172.16.5.29:1869 idle 0:01:33 Bytes 36
FLAGS - D
UDP out 4.2.2.1:53 in 172.16.5.29:1869 idle 0:01:24 Bytes 36
FLAGS - D
UDP out 4.2.2.3:53 in 172.16.5.28:3869 idle 0:00:29 Bytes 36
FLAGS - D
UDP out 4.2.2.2:53 in 172.16.5.29:1869 idle 0:00:49 Bytes 36
FLAGS - D
UDP out 4.2.2.3:53 in 172.16.5.28:3869 idle 0:01:51 Bytes 36
FLAGS - D
UDP out 4.2.2.2:53 in 172.16.5.29:1869 idle 0:00:48 Bytes 36
FLAGS - D
UDP out 4.2.2.2:53 in 172.16.5.29:1869 idle 0:01:47 Bytes 36
FLAGS - D
UDP out 4.2.2.3:53 in 172.16.5.28:3869 idle 0:00:24 Bytes 36
FLAGS - D
UDP out 4.2.2.1:53 in 172.16.5.29:1869 idle 0:01:47 Bytes 36
FLAGS - D
UDP out 192.168.255.255:138 in 192.168.18.20:138 idle 0:00:46 Bytes 2946
FLAGS -
UDP out 4.2.2.2:53 in 172.16.5.29:1869 idle 0:00:23 Bytes 36
FLAGS - D
UDP out 4.2.2.1:53 in 172.16.5.29:1869 idle 0:01:50 Bytes 36
FLAGS - D
UDP out 4.2.2.2:53 in 172.16.5.29:1869 idle 0:01:23 Bytes 36
FLAGS - D
UDP out 4.2.2.1:53 in 172.16.5.29:1869 idle 0:00:27 Bytes 36
FLAGS - D
once you do "Clear xlate" everything is normal.
Please let me know if anybody knows what the issue was ?
Re: DNS query problem in FWSM
hi
try to change the default value of 3 hours in 3/5 minute:
"timeout xlate 3:00:00"
in
"timeout xlate 0:03:00"
or if nothing happen
do
"no fixup protocol dns"
hope this help
ciao
davide
Thanks for your
I did this. But still we are getting this problem.
Please help us to resolve this problem.
hi
two other things that help me to resolve a similar issue:
* have you tried the c6svc-fwm-k9.2-3-3-2.bin? (if not upgrade!)
* try fixup protocol dns maximum-length 1500 (the default is 512 and the fwsm drop packets that are larger than the configured maximum length)
ciao
davide
382
