do not shunning a network and hostname with sensor v3.01
i configured director 2.2.3 and sensor v3.01,i have managed router ,I clicked shunning enable ,it was succeed,when i click shun network or shun hostname ,i entered ip address with shunning ,it was display "timeout on waiting for respones",i clicked network device(security menu),it was display
disable shunning
success
configuring termial
error :timeout on waiting for respones
exiting the termial configure
success
applying netranger acls with logging enable
success
Re: do not shunning a network and hostname with sensor v3.01
What do you see when you do a Security->Show->Deamons->Status?? Is managed running??
If not, have you configured it using security->Configure, select the sensor, go to Device management...set up the router(s) then System files->daemons and enable managed there??
when i do a security->show->demons->status,managed is running,I have configured the sensor ,when i do shunning ->enable ,it is success. but
i can not shunning a network or hostname ,it is display "timeout on waiting for respones"
Nr.managed receives a shun request message when a host or
network shun is performed from the Director. Nr.managed should
respond immediately, with success if it was a valid shun request,
or with failure if the request was invalid. It will send this response
before it actually attempts the shun. It should never happen that
managed will respond to some requests (e.g. ShunEnable) but
time out on others. There is probably a configuration problem,
or perhaps I don't completely understand your description.
In order to investigate and solve this, can you open a TAC case?
If the TAC engineer can not immediately find a solution, ask them
to assign stleary@cisco.com as the DE, and I will take a look.
95
