Dot1x NAC reauthentication issue
cheaseung
i setup a test LAB with NAC Dot1x Framework, and i facing an issue where by the port keep on repeating triger reauthntication, althought the next reauthentication is not yet reach, i try configure re-authperiod to using local rather than radious server or event disable the reauthentication but the result is still the same
my lab is using a Cat3560 event upgrade with latest IOS ver c3560-advipservicesk9-mz.122-40.SE but is still the same
when show dot1x interface detail i notise the next re-auth is still alot of sec, but out of sudden the port juz reauthenticed, whereby the CAT detail show status reauthenticating,
CAT version 2.1.103.o with supplicant bundle.
i event try to modify the ctad.ini
SQTimer and all this make no difference
thx
5 Replies 5
jafrazie
Can you verify the source of your unexpected re-auth?
If it's the supplicant, you'll see an EAPOL-Start on the wire to initiate it (or maybe an EAPOL-Logoff, but unlikely).
If it's the switch, you'll see an EAPOL-Id-Request frame on the wire from the switch to the supplicant to initiate it.
Hi jafrazie,
i didn't saw EAPOL-Start or EAPOL-Logoff Request from the debug dot1x packet
in debug dot1x all it show
.Sep 15 12:16:43: dot1x-ev:dot1x_exec_reauth_client: Reauthenticating Authenticator instance on GigabitEthernet0/41
.Sep 15 12:16:43: dot1x-sm:Posting REAUTHENTICATE on Client=31CC01C
.Sep 15 12:16:43: dot1x_auth Gi0/41: during state auth_authenticated, got event 18(reAuthenticate)
.Sep 15 12:16:43: @@@ dot1x_auth Gi0/41: auth_authenticated -> auth_restart
.Sep 15 12:16:43: dot1x-sm:Gi0/41:000b.db1b.9eac:auth_authenticated_exit called
.Sep 15 12:16:43: dot1x-sm:dot1x_auth_stop_reauth_timer called for 000b.db1b.9eac
.Sep 15 12:16:43: dot1x-sm:Gi0/41:000b.db1b.9eac:auth_restart_enter called
.Sep 15 12:16:43: dot1x-ev:Sending create new context event to EAP for 000b.db1b.9eac
.Sep 15 12:16:43: dot1x-sm:Gi0/41:000b.db1b.9eac:auth_authenticated_restart_action called
.Sep 15 12:16:43: dot1x-sm:Posting !EAP_RESTART on Client=31CC01C
.Sep 15 12:16:43: dot1x_auth Gi0/41: during state auth_restart, got event 6(no_eapRestart)
.Sep 15 12:16:43: @@@ dot1x_auth Gi0/41: auth_restart -> auth_connecting
.Sep 15 12:16:43: dot1x-sm:Gi0/41:000b.db1b.9eac:auth_connecting_enter called
.Sep 15 12:16:43: dot1x-sm:Gi0/41:000b.db1b.9eac:auth_restart_connecting_action called
.Sep 15 12:16:43: dot1x-packet:Received an EAP request packet from EAP for mac 000b.db1b.9eac
.Sep 15 12:16:43: dot1x-sm:Posting RX_REQ on Client=31CC01C
.Sep 15 12:16:43: dot1x_auth Gi0/41: during state auth_connecting, got event 11(eapReq_no_reAuthMax)
.Sep 15 12:16:43: @@@ dot1x_auth Gi0/41: auth_connecting -> auth_authenticating
.Sep 15 12:16:43: dot1x-sm:Gi0/41:000b.db1b.9eac:auth_authenticating_enter called
.Sep 15 12:16:43: dot1x-sm:Gi0/41:000b.db1b.9eac:auth_connecting_authenticating_action called
.Sep 15 12:16:43: dot1x-sm:Posting AUTH_START on Client=31CC01C
iz switch itself genarate the re-auth itself
what could cos this?
could it be something wrong with my config, i do try without NAC, just purely dot1x authentication with original winXP SP2 is still the same
thx,
LIMCS
Your psec configuration is most likely tripping a re-auth on you every minute. OUY could set the aging criteria to inactivity, or ..
I would humbly recommend disabling psec in this scenario. 1X itself will limit the port to only a single MAC anway, and there's no such thing as aging for it really .. after all, that's why you might want re-auth for to begin with.
Hope this helps,
hey jaffrazie,
thx alot, u r so great
Thank you, man. I solved my issue )))
