Dot1x reauth
I have a switchport configure for dot1x in multi-host(I have a 7911 connected). The switchport is re-authenticating me at regular intervals. It make sense to do that but were is it documented?
CSL02ZD#sh dot1x all
Sysauthcontrol Enabled
Dot1x Protocol Version 2
Critical Recovery Delay 100
Critical EAPOL Disabled
Dot1x Info for FastEthernet1/0/2
PAE = AUTHENTICATOR
PortControl = AUTO
ControlDirection = Both
HostMode = MULTI_HOST
ReAuthentication = Disabled
QuietPeriod = 60
ServerTimeout = 30
SuppTimeout = 30
ReAuthPeriod = 3600 (Locally configured)
ReAuthMax = 2
MaxReq = 2
TxPeriod = 30
RateLimitPeriod = 0
Re: Dot1x reauth
7911 ip phone?
The switchport should NOT be re-authenticating you at regular intervals. You have re-auth disabled via show command output.
What switch/image is this? Does this occur where there is no phone in the mix?
Re: Dot1x reauth
C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEE1
Sorry, mistake here, my lab setup is with a 7912. The reauth occur at 90sec intervals.
Will I have the same thing with 7911,7940-1,7960-1,7970...I have every phone model on my network.
263
