Community Member
Downloadable ACL Timout settings?
I have two questions regarding Downloadable ACLs as it relates to PIX 515 E and ACS 3.0.2:
1. How long after the user disconnect, the temporary ACLs created by downloadable ACLs remain on PIX and are visible thru "show access-list"
(ie: access-list #ACSACL#-PIX-acs_ten_acl-3b5385f7 permit ip any any). I've seen them still there even an hour after user has closed it's session.
2. Also, I've noticed that a user who is authenticated and gets access to a web server via downloadable ACLs can still go back to the web site even a few minutes after closing all web browsers. How is this intervals adjustable?
Thanks in advance.
1 REPLY
Community Member
Re: Downloadable ACL Timout settings?
When you do a clear xlate not all translations are droppped try using clear local host, this could be the reason why even after you disable a acl some connection are able to work.
210
