Downloadable ACLs on ACS 3.3
Hi everyone. I`m having a problem with editing a downloadable ACL on our ACS 3.3.
Whenever I try to edit an ACL in the shared profile component section, I add what I need and then click submit but the changes don't seem to save... As soon as I go to another menu, my changes are gone. Is there something I`m forgetting?
Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Downloadable ACLs on ACS 3.3
After you have edited the ACL and you click "submit" on the page with header
Downloadable IP ACL Content
you must then click "submit" again on the page it takes you back you ie. the one headed
Downloadable IP ACL's
Jon
Jon
Wow, I should have seen that before... Thanks!
100
