Dropped packets on Vlan interface
Hello, we've recently been experiencing issues with connectivity to one of our service providers. The network is on a vlan switch trunked into a Pix 515.
Personally I don't think that the dropped packets are the cause of the problem - but I just want to know is it normal to have these drops? Also they are incrementing as I had cleared the counters today - please see below:
TIA
Interface Ethernet2.54 "bny", is up, line protocol is up
VLAN identifier 54
Description: ***BNY SP LINK***
MAC address 000d.8810.7010, MTU 1500
IP address 192.168.0.1, subnet mask 255.255.255.0
Received 39783 packets, 13724740 bytes
Transmitted 29182 packets, 10437172 bytes
Dropped 257 packets
Re: Dropped packets on Vlan interface
these drops are normal. may be you have the trunk not set correctly. may be you are sending vlan packets that pix is not configured for.
thanks
Nadeem
Hello Nadeem - this is the response after 1 day - the drops are a great percentage of the overall traffic - see below - I've also posted the partial configs of both switch and firewall -thanks
------------here's the physical interface stats:
Interface Ethernet2 "", is up, line protocol is up
Hardware is i82559, BW 100 Mbps
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
Description: ***PHYSICAL LINK TO EXTRANET VLAN SWITCH***
Available but not configured via nameif
MAC address 000d.8810.7010, MTU not set
IP address unassigned
3985926 packets input, 1071610479 bytes, 0 no buffer
Received 52304 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2470303 packets output, 347691667 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/67)
output queue (curr/max blocks): hardware (0/24) software (0/1)
---------------now here's the problematic interface:
VLAN identifier 54
Received 800563 packets, 361416438 bytes
Transmitted 690914 packets, 49565490 bytes
Dropped 535499 packets
112
