11-24-2003 08:08 AM - edited 03-09-2019 05:38 AM
we have a system consisting of a cisco pix 515 and a cisco 2621 router. the pix is doing our firewalling and the 2621 is doing all our site to site vpn routing. problem we are having is with a static route on the 2621. this route tells the lan to go out through the firewall to get to an outside server. we have 3 routes pointing to services outside the pix. 2 of these routes work perfect and the main route we need to work keeps failing. if i remove the route and reenter it sometimes it works for a while sometimes it does not. anyone have any ideas? thanks
11-24-2003 12:49 PM
Can you elaborate on what you mean by "the main route we need to work keeps failing"? Configurationwise, what is different between this route and the other two?
11-24-2003 03:00 PM
there is no difference between the routes
2 of the routes are for outside printers
1 route that is giving us problems is to an outside payroll server.
config is like this
142.*.*.5 is the outside of the 2621
10.0.0.1 inside
142.*.*.200 outside of the pix
10.0.0.200 inside of pix
def gate of lan is 10.0.0.1
routes in 2621 are like this
142.*.*.250 255.255.255.255 10.0.0.200 payroll app
142.*.*.229 255.255.255.255 10.0.0.200 printer
142.*.*.225 255.255.255.255 10.0.0.200 printer
the printers work fine can print and ping them but for some reason the payroll app server starts to become unpingable even though the route is still listed in the router.
